Past Problems:
* ROPS mounted work lights attracted bugs in warm weather and probably because I wear glasses, provided glare year-round. This was true with halogens and LED's.
* LED's mounted on the ROPS and cab roof made it difficult to see where the cut / uncut grass met. I'm guessing it has to do with the angle of the light hitting the ground and the LED color temperature?
Rear-facing lights aren't as important in this case. They are just there to see trees and other things I don't want to back into.
What works now:
* Forward-facing lights are mounted in the grille guard. Being mounted much lower makes the light hit the ground at a sharper angle and makes it easy to see cut / uncut. Kind of like seeing how wavy vinyl siding can look when the sun hits it at a certain angle.
* Side lights mounted low make it a lot easier to see exactly where I need to turn. I just added these after a 10:00PM finish earlier this week. There were a number of times I needed to back up so the front lights could light up where needed.
Had it out for a trial run last night and am very happy with the results. Depending on schedules and weather, night mowing is fairly common for me.
What works now:
