Any affordable pallet forks for a BX2370?
Dark Age 53
BX2370
Feb 25, 2017
38
Dewitt
Checked with a couple of local Kubota dealers and they want $850/$900 for one, I'm looking between $400 and $600 max. I have the LA243 FEL with the Kubota quick connect. BTW, I'm not interested in the bolt on forks. Thanks
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
palletforks.com will be right up your alley, if solely shopping by price.
Pay attention to the weight of them, as it will effect your loaders capacity, to a degree.
Dark Age 53
BX2370
Feb 25, 2017
38
Dewitt
we love our Titan forks, we got the UA made in USA ones. Get light weight ones for a BX, and get ones with adjustable forks
I should hear back from them tomorrow if they make them for the BX2370, they may have them but I can't find them on there web site.
dalola
BX2380 w/FEL & Woods RM48 RFM, Yazoo/Kees Max2 ZTR
Jun 30, 2017
316
Assuming you're referring to the type that clamp on the FEL bucket.... Given the lift capacity of a BX, they are actually a very effective, economical option. Just food for thought. :)
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
Agreed. I've recently used mine to unload a 575 lb. log splitter off of a delivery truck with my BX. Not sure of your needs but if money is a limit, worth looking into. What do you have for counterweight?
Sent from my SM-N960U using Tapatalk
Dark Age 53
BX2370
Feb 25, 2017
38
Dewitt
I gave those some thought but would rather go with the pallet fork attachment. Thanks for the reply.
rlcotter
BX23S Cab;3pt Blade;HLA Snow Pusher;BX Armour;HLA Fork;Ratchet Rake, Snow Edge
Mar 24, 2016
50
Ontario, Canada
I have a BX23S with the quick attach. Purchased a set of forks through my dealer made by HLA Attachments for $500 Canadian dollars ($375 US?). Use them almost every day for something. Quick switch from bucket to fork lift. I looked on their website and they have a distributor in Carson City, MI.
Best regards,
Les
Dark Age 53
BX2370
Feb 25, 2017
38
Dewitt
Best regards,
Les
Can you post a photo of your forks, there web site doesn't really show much. Thanks
5,557
I've never seen the type of connection you have to the bucket. To me, it looks like a pinned bucket not SSQA mounting. If that is the case, I'd also suggest clamp on forks as others mentioned. They would be easy to install/disconnect and would not significantly cut into your limited lift capacity.
Perhaps you could find the other type that attaches by hanging from the upper lip of your loader bucket?
6,779
Dark Age 53, your pictures do not show a quick disconnect bucket or loader system. A quick attach looks like this. It is mounted on you loader arms and stays there. It fits into various implements and can be changed out in a couple of minutes.
For your forklift needs the clamp on is MUCH less expensive now that you don't have the other brackets.
jmf78
Nov 5, 2015
437
Edinboro, PA, USA
It appears he has some other sort of quick attach device that works with pinned buckets. Similar to ai2 products seen here: https://bxattachments.com/product/2-8-hd-quick-attach-gen-3/
