BX22 won't stay running in "RUN" position
Mikes BX22
BX22LB
May 28, 2019
Endwell
My BX22 with 300 hrs. on it just stopped while I was running it. It will start and run only if the key is held in the start position. I've seen this posted here, and I'm trying to locate the relays. They must be well hidden.
5,235
1,018
Sounds like a problem with the seat switch not a relay at 300 hrs
6,382
Check fuses and then more likely the stop solenoid is either bad or not getting the proper input.
Its got a twin coil solenoid, when the hold coil goes out it will act like what you are describing, a simple input test on the wiring to the solenoid will tell ya if it's got power or not.
