Have searched a lot and still not sure what others do. The question is, how long do you keep the same hydro filter installed? The manual calls for hydro filter and fluid change every 300 hours. That could be 6+ years in my case.
I called Donaldson and they said their filters are designed per manufacturers specs. They would not commit if the filter would perform if the 300 hours of service was several years. I also called Baldwin and they would not commit either but did recommend that the safe thing to do is change the filter annually.
Changing the filter every year or two is not a huge deal accept from what I read their will definitely be fluid loss. And buying a gal of fluid just for a filter change seems silly.
Another option is the "vacuum over the fill port technique" while changing the filter. Does that actually work?
