Best B-Series (based on reliability)
simpson1
l4240 and b1700
Feb 7, 2017
27
Iowa
I'm looking to buy a different tractor and I'm really looking for something that is reliable. In your opinion, what year/model is the most reliable? I really like this 2009 B2620 4wd with 250 hours that is for sale. What do you guys think, how much is it worth? Its in excellent condition and a mower deck is the only thing included. I'm open to other models as well.
2,551
what is the cost of the B2620 you are looking at buying?
That is an excellent machine fwiw.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,377
384
Well only thing I can say is look at what I do with my 2013 B2620 here:
http://www.orangetractortalks.com/forums/showthread.php?t=34775
It has 625 hours now, and it works hard every one of those hours.
So far the only issues are:
Carlisle replaced my tires free of charge because the sidewalls all cracked. No leaks, but looked bad.
And the loader joystick broke off where it is only tack-welded to the base plate that the bolts go through. And now that square block that the joystick bolts to must be getting wore because it has some slop in it.
But I really use my loader probably more than these little tractors are designed for, LOL.
Everything else is perfect. Easy on fuel, easy to work on. No electronics.
6,394
B7100 Hands down...
But there are much newer models out there.
I honestly can't think of any "bad models", most all of them are good, some are just better than others.
Hours, Maintenance, Wear and Tear, Abuse or just plain use, can all play role in how good the tractor is.
simpson1
l4240 and b1700
Feb 7, 2017
27
Iowa
I currently have a B1700 but I want something newer. I had a problem with my bi-speed which I couldn’t figure out but I eventually did. Before I tell you guys the price, I want you to guess. It’s extremely clean. What would you say my 1997 B1700 HST 4WD is worth? It is a 2 owner machine and has 930 hours. It’s not in excellent condition by no means but it looks nice for its age.
edritchey
A bunch of cute little Kubotas
Jul 19, 2014
1,107
806
Wellsville, PA
I have a 1981 B8200E that's still going strong after almost 40 years of mowing. I don't know how they compare to the B7100 you mentioned but it's been a real good tractor.
I also had a B7200HSD with a loader for many years it to was a real work horse for a little tractor.
B7100 Hands down...
PaulL
2,441
1,366
NZ
The B models generally build one on the other - so usually a newer one will be as good as the older with some improvements. To me the question is how much money you have, then you buy the newest one you can afford. I'd say a brand new B2650 would be an excellent buy, but if you can't afford that then a B2630 is also a very good machine.
SDT
multiple and various
Apr 15, 2018
3,256
1,042
SE, IN
B1750.
Bought mine new in 1993, and it has needed absolutely nothing since I bought it. Nothing. Not so much as a fuse, fan belt, lamp, or hose. Nothing in over 26 years.
Yes, it does get good maintenance, is kept inside, and is not abused.
SDT
dlundblad
G5200, L2501, ZD1211
May 16, 2009
503
10
IN
B1750.
SDT
Very nice.
That’s the first Kubota I remember my dad having. Had 2 sets of tires. Ags and turfs. I remember it being a big deal when the newer tractor only needed 1 set (industrials) Lol.
5,583
I bought a B8200 new in 1985 with loader and mid-mount mower. Never had one thing go wrong with it. I changed oil, fuel, air filters and kept it in a barn. Sold it two summers ago because I had too many tractors. Still had original turf tires on it.
Had a B6100 bought new in 1980. Just used it for mowing. Same deal...replaced the clutch once because operator error, and fixed the cam plug.
I never had an offer for dealer supported insurance/warranty then. I never took either of those tractors to anyone for any service. I'm not sure if I bought a new Kubota today I'd bother with the expense of the dealer warranty.
MadMax31
BX23S, 60" MMM
Nov 5, 2014
766
New York
B3200.
Hot Rod in Kubota Orange. All of Pros of the new B3350, none of the DPF issues.
If were talking new on a lot, B2650 is the only B I would buy.
SDT
Apr 15, 2018
3,256
1,042
SE, IN
B3200.
Can't argue with that, Max.
I looked for a good used B3300 off and on for nearly two years before buying my B3350. None were to be found within reasonable buying distance.
After buying the B3350, they seem to be everywhere.
No. A B2650 does not have enough power.
SDT
