Re: Kubota Extended Warrenty - worth it?
I've never purchased an extended warranty on any of the 10+ Kubota's I've owned and out of the 10. I've only had 2 issues. One was a cylinder seal (Kubota took care of that under the basic warranty) and a leaking bung on my right fuel tank on my cabin M9. Kubota took care of that issue as well. Provided me with a new tank that I installed myself.
I consider Kubota to be a well built and engineered unit but as with all complex mechanical apparatus, things do fail.
Looks to me like your issues stem from too little a unit trying to do too large a task.
Looks to me like you beat the tar out of it.... Maybe you should have purchased a larger unit with more capacity. I believe a JCB would have been a better bet for you but then, you'd probably destroy that as well.Hi, I have a 2019 B2601 with a 54" quick attach bucket, BH70 backhoe w/12" bucket. and 54" mid mount mower. At approx. 125 hrs. the hydraulic cylinder shaft that works the backhoe bucket snapped in two pieces. about 20 hrs. later the replacement shaft bent neither covered under warranty, keep engine speed at 2000 and no more problems at 235 hrs. Arms for quick connect frt bucket started coming off during use occasionally at under 200 hrs. breaking headlight assembly. took to dealer for pictures to show field rep. for kubota here is response.
KTC Customer Satisfaction <ktc_g.customersatisfaction@kubota.com>
To:craig
Fri, May 1 at 3:33 PM
RE: B2601HSD SN:
Mr.
You recently opened a case with Kubota Customer Satisfaction regarding damage to your B2601. Your case was reviewed by our Kubota Service Representative, and he has found that the damage was due to improper operation of the equipment. Unfortunately, this type of damage is not something that warranty covers.
Regards,
Ruth G.
Digging tree stumps with backhoe and cleaning edge of pond, moving firewood and approx. 100 dump truck loads of dirt, moving dirt of 1/2 acre lot.
Kubota seems very good if you leave tractor in garage and look at it, so far approx 230 hrs. on tractor no problems with mower.
