Welp! Its beeen a while!
BlownL67
71
West Springfield, Ma.
So I finally got 2 beautiful days to get my B7200 into working order! The tractor only has 280hrs on it, but there has never ever been a bit of maintenance done.
Here is the rundown of what I've done:
replace every rubber bucket line
replace every hardline from controls to bucket
oil/filter change
new air filter
new hydraulic filter screen
flush UDT and add new SUDT
radiator flush + new coolant + t-stat
drain and fill from axle housing + ends
Some of the fluids I drained out were aboslutely disgusting! She runs like a top now, but I got a leaking bucket cylinder (B1630)! I called the dealer and they stock repack kits for $33/ea. Since I am going to be repacking one, I might as well do the other. Before I go nuts doing this, are there any special tools or bits of knowlege I need to know before I dive in ? The dealer told me they can do it in about an hour with a labor rate of $60 which isn't too horrible, but I think I'd rather tackle it myself.
Any help would be appreciated! -
Thanks - Mark
VashonFarmer
B8200
Mar 11, 2010
14
Vashon, WA
oil/filter change
new air filter
Thanks - Mark
Hey Mark,
Mind if I ask if you did it? I'm hoping to tackle the same cylinder repair on a BF300 (B8200 tractor). I noticed you didn't get any other replies, but hoping that you braved it anyway. :) I'd love to learn from you!
The only bummer so far is that the repair kit runs $77 per cylinder for my unit. Don't know why such a disparity, but that's life.
Thank you,
Andy
Theekillerbee
273
Pleasant View UT, USA
Changing out the guts on a ram isn't all that bad. Make sure you are in a clean shop. Having a parts washing tank is a bonus, but not required. Pay attention to how the thing comes apart. Sometimes you'll find an O-ring or 2 that you don't see at first. Also most rams have chevron style pressure rings. They must go in a certain way! Make a note of how they came out. If put in upside down, you will not be able to pressurize the cylinder properly. One other nice thing to have is a cylinder hone and an extension bit. Hone that thing out to ensure your new rings last longer. Doesn't take much, just a minute or so through the inside of the bore.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
676
147
Rising Sun, MD
K-Bee,
I believe you honed your cylinder. Can you share with us how long the cylinder was and what kind of hone did you use?
I have a hone but it is for automotive cylinders.... not long enough to do a loader cylinder even if honed from both ends...
Have a great day! Butch
Theekillerbee
273
The latest cylinder I rebuilt was about 30" long. It came off an old Ford backhoe. I use an automotive cylinder hone, but have a drill bit extension, can't remember where I bought it, but i'd bet most hardware stores carry them. I put the hone on the extension then the extension on the drill. Good luck.
