Which rear u-joint? There are two rear u-joints. One on the deck drive shaft and one on the shaft between the motor and transaxle. The transaxle shaft joints, I got at the dealer. Haven't had to do the deck shaft (yet) so I can't comment on that one.
If you're doing the transaxle shaft joints, look CLOSELY at both yokes. They tend to wear out where they're splined, and will cause lots of vibration. Replacing them makes it run 10x smoother!
