hi im looking to buy a 3pt hitch assembly for my b 7100 does anyone know exactly what im looking at in cost and where i could buy one.
That looks like the same I have bought.I got mine through Vic here. Looks very much like this listing
http://cgi.ebay.ca/3-POINT-HITCH-KI...611?pt=LH_DefaultDomain_0&hash=item35b3fe13fb
does that kit include the arms that attach to the lift shaft. its the shaft that has splines on it. it is located right under the seat. and does it include the hardware to attach it. I have another question my hood of my tractor says b7100 but the serial # is stamped b7001 52849. what is the difference in the two and will this kit work for me. thanks BrentThat's the one I bought. The fixed lift arm was welded at the wrong angle but other than that, its been good.
I also needed to buy two extra spacers or my b7001.
Let me know if you want some more info or search for my thread on this subject ( from the spring)
Now a picture would be good. Because I understood, that your tractor has even not the arms to lift. You only have the empty shaft ?does that kit include the arms that attach to the lift shaft. its the shaft that has splines on it. it is located right under the seat. ...
I would call Kubota dealers and ask if they have or know used up tractors which are used as spare-parts-holder.well i got the hitch but i still need the arms that spline to the shaft under the seat where can i get them? any ideas
