I have a L2050 four wheel drive. When going down a slight incline with a load, I get chatter from the left side when I apply the brakes. Is there a solution to this problem?
Do you have the proper oil in the trans/diff (or Hydro) sump?I have a L2050 four wheel drive. When going down a slight incline with a load, I get chatter from the left side when I apply the brakes. Is there a solution to this problem?
I bet it is....I have an L3710 and have removed the axle housing and unbolted the brake housing and am now confused about how to get at the discs. Does the shaft, bearing,discs and housing pull off as a "unit"? So far, this job has been maybe more than I bargined for.
But Judge is recent, very recent. 7 years is a lot of time to do a brake job....lolio540's post is 7 years old. So he probably won't answer.
Do you have the WSM (aka service manual)?I have an L3710 and have removed the axle housing and unbolted the brake housing and am now confused about how to get at the discs. Does the shaft, bearing,discs and housing pull off as a "unit"? So far, this job has been maybe more than I bargined for.
