L 245 DT Brake repair
planes41
L245DT
Apr 9, 2019
Murfreesboro, TN
Purchased the tractor 3 years ago and operated it in an "as is" condition. Great running tractor so I decided to repair "sticking" left brake and pulled it apart. The boss spline was seized on the axle shaft and I was able to remove it from the axle by applying some heat to the boss spline.
The brake part surfaces and teeth do not show damage / wear. The cam brake moves freely. I need guidance on the "sticking" root cause.
The boss spline does not freely slide on the axle shaft. I am suspecting there may be a slight twist in the axle causing the boss spline to be immovable.
Any guidance is most appreciated. Thanks!
motionclone
May 4, 2018
1,399
996
Maine
Post up some pics. But first youll need, I think, 5 posts to be able to post pics so respond to this and some other threads to build your count up. I have a 345dt which i think is similar to yours so im curious about your issue.
