L2850 3 point hitch problem
waltweems
L5030, L35
Nov 10, 2015
10
cooksville
My L2850 3 point lift suddenly stopped lifting. Fluid level is OK. I'd appreciate any thoughts on this problem,
rbargeron
Jul 6, 2015
1,183
260
western ma
Hi Walt - here's a page from the WSM on troubleshooting. Most common problem is the o-ring in the main lift cylinder under the seat.
9,127
Usually when I hear" The three point suddenly quit working" it's associated with the feedback linkage, either damaged or disconnected.
fisherfishing64
L2850
Apr 27, 2019
whitehall, MI
I am also having the same problem with the same tractor. I have pressure for my PS, have pressure for auxiliary items i.e. log splitter, my 3 point will lift with no load on it slower than usual. It will also hold a load with no drift down once up (if you lift load by hand). I have replaced the filter, taken apart the pressure releif valve on top of piston under seat cleaned and replaced adjust to provide more pressure, taken the the feedback lever off and manipulated it by hand. Anyone figure anything out with theirs?
