***129300; so here is the truth. I am in this machine for 2000. Motor runs great, but that alone won’t cut my grass. I can source a pump that Was working and is in a machine being parted out. Should I buy that disassemble inspect etc. it is like 500 bucks vs 1900 for the new.
I also need a charge pump and a back case plate as the shavings quickly destroyed the charge pump
Soooo..
Are you recommending I dissembled the wheel drives of both sides and the HST on both sides?
This was my thought
Dissemble. Clean with brake cleaner get all shavings out. Are the bearings ok so long as they are spinning freely without wear?
Blow everything out with compressed air. Relube with Super UDT and then re assemble.
What is a good running zd 28 worth? This one has a pro deck and only 500hrs. I think I may be upside down on this project already. Should I just abandon ship and part this thing out?
Soooo..
This was my thought
