Looking at getting a Kubota Z100 Series mower. Anyone have any input as far as issues and or concerns with them.
I haven't found my diesel Kubota to drive or behave any different than a petrol machine, other than using less fuel and having more grunt. But ultimately you turn the key and it starts, you drive it, you put it away. You have to fill it with diesel, but I might rudely assume you'll need to do that for her anyway....will she really notice the difference?Diesel isn't her thing.
After working on Diesel equipment and arriving home I tend to get greeted with "Your Stinking Up The House" and them she wants to strip me down and hose off in the back yard, which is quite fun in the summer not so much in Fall, Winter and spring.I haven't found my diesel Kubota to drive or behave any different than a petrol machine, other than using less fuel and having more grunt. But ultimately you turn the key and it starts, you drive it, you put it away. You have to fill it with diesel, but I might rudely assume you'll need to do that for her anyway....will she really notice the difference?
How steep are your hills?Just my 2 cents;
I'd love to have a zero turn but have been warned by countless people that it wouldn't work very well with the hills that I have. If your property is fairly flat, go for it but if not some more research my be in order.
Steep inclines can be exciting on a ZT and I wouldnt recommend a ZT for inexperienced or less skilled operators...especially if you have things like trees, rocks and bodies of water to deal with. Turf tires on slopes and wet grass can be like driving on ice. Get the R4 style bar tires for sure.On the worst one the inclinometer says 40 degrees, others in the 30-35 range.
That's pretty much where I'm at. Agreed, not as much fun but safer so I'll stick with using the BX with R4s. Slow but stable.Steep inclines can be exciting on a ZT and I wouldnt recommend a ZT for inexperienced or less skilled operators...especially if you have things like trees, rocks and bodies of water to deal with. Turf tires on slopes and wet grass can be like driving on ice. Get the R4 style bar tires for sure.
If you have a lot of obstacles and steep slopes an HST 4WD mower/tractor might be a better option. Slower, but more controlled with less slide. Not as fun as using the ZT.
