My tractor came with Super UDT from the factory (2004). My 5 gallon bucket is getting low, and now I see that they are selling Super UDT2.. What is the difference? thanks
Check out specs herehi ^_^ i have a little question about the UDT oils to, What color are they suppose to be???? Also id like to know what index they are ( SAE W???? ?w? ) so i can pick a replacement for them.
Why are you looking for a substitute?Thanks for the quick reply, but that is the problem - there was the firs place i looked but they don't tell if its 10w30 Sae or not. I found a oil that should be a substitute and it says it is, but is it???? OMV austromatic LVX SAE 10W-30 (UTTO)
Actually, that link does indeed specify the viscosity index with a chart at the bottom of the page.Thanks for the quick reply, but that is the problem - there was the firs place i looked but they don't tell if its 10w30 Sae or not. I found a oil that should be a substitute and it says it is, but is it???? OMV austromatic LVX SAE 10W-30 (UTTO)
Orange....Why are you looking for a substitute?
Personally....Let me give you some unwanted fatherly advice. Tractors are expensive. Tractors are real expensive when they break. Spend the extra money and use what the manufacturer recommends.
I would think that even in bulgaria you should be able to find hydraulic fluid, no matter the brand name, that will state right on the label UDT compliant, that's all you would need to find.hi ^_^ i have a little question about the UDT oils to, What color are they suppose to be???? Also id like to know what index they are ( SAE W???? ?w? ) so i can pick a replacement for them (will Sae 10W30 be a right choice??).
It's because i need to change it. the old one is F*c*ed. Currently i can't find UDT (maybe i can get some but it will be a long process and probability at a price twice the real one) and so i need to use something that is compatible.Why are you looking for a substitute?
Yes. i phrased that wrong, sorry!! ^^" What i meant was that it does not say if it really is a 10w30 (75w80) or not. Just trying to see if the dealer is correct or just replays on auto for every question.Actually, that link does indeed specify the viscosity index with a chart at the bottom of the page.
Sounds like you either have air becoming entrained into the fluid, check all suction line connections and hoses for seeping leaks, or you have damaged three point cylinder seals.After few minutes of work the tree point that lifts the plow stops working, after some rest it starts again, but until it warms again. currently i'm waiting for a new hydraulic filter(it's said that it's reusable, but i'll change it anyway) to see if this changes something.
For Super UDT2 we've gotten local prices from $94.50-$108. per 5 gallon bucket.Cost?.................
