quick hitch
kubotajay
Kubota b2650, 534 ller, land pride planeader, land pride reverse t
Mar 2, 2019
Midwest
does anyone use a qh15 quick hitch on their tractor? Does it work well? whats a fair price to pay for one from a dealer?
9,531
I don't have a LP QH but the QH15 is the best model that LP makes.
I've used a HF knock off for 4 years now and it works perfectly fine, and I think I paid $79 for it, could afford to replace it several times over if it does fail. ;)
erik21788
B3300SU, LP FDR1660, WOODS HC60
Jun 21, 2018
10
Thurmont, MD
I use a QH15....I love it cause of the adjustable top link hook. Believe I paid around $400 from dealer for it....but unless others have had issues with other brands like HF or TSC brand, I don't see a difference in them, other than price, but a Quick Hitch is the way to go
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
Bought the QH15 last year and it was $375 delivered to my house by the salesman.
I enjoy mine and bought top links for most of my implements so I could swap them out and then each implement was very close to being set to use.
I'm sure other brands will work fine as well but no complaints with my Landpride.
3,682
A QH is valuable if you often swap between QH-compatible implements... but not so much fun when/if you are swapping out a non-compatible implement or if swapping out with something like a Post Hole Digger/Auger which will not ever mate up to a QH. Then the irritation of removing / reinstalling the QH becomes the irritation.
I plan to make a PHD stand on rollers similar to the one shown in JD Green at youtube…. but add at the opposite end a mount for my QH so I can dismount the QH onto one end of the PHD-stand and then turn it around and mount the PHD... and reverse the procedure later.
https://www.youtube.com/watch?v=ecpHhyUAbc8
Forvols
104
Hawkins county TN
QH15 here on my L2501 it was spendy compared to other brands. Works great with LP cutter and boxblade, also no issue with my countryline carryall.
2,449
Edritchey has a QH15 for sale in the sale/trade section
Knott
2015 BX2670-1, BX2755HD Snow Blower, Farmking 4' box Blade, BX 2760A Plow Blade
Jun 2, 2015
101
Manitoba
I have had & used my QH15 since the day 1, June 2015. It is a life saver. It’s adjustable top link hook is great. I do not regret buying it at all. Even though l have had to purchase bushings to adapt the lower pins of my 3 point equipment, it is a small price to pay to have such a versatile quick hitch at my disposal. As for price l can’t say as my dealer threw it in when l bought the BX2670.
Creature Meadow
Sep 19, 2016
1,065
140
I have the QH10 on my L3301 , I didn't want to keep up with Cat 1 to Cat 2 bushings.
Took a piece of steel round stock and bored a hole through it and cut to length, now I have bushings that stay with each implement.
Works great, other than my brush hog my QH works on all my implements with no fuss just back up to them pick them up and lock down levers.
5,504
2,213
Something worth noting is that if one is buying a new tractor/loader/trailer as a package, Kubota will allow one to purchase the package with 3 implements. One is the loader, another the bush hog/box blade/finish mower, but then there's a third. The QH15 is considered a qualifying implement and thus can be financed in for the package deal price.
Dennis.D
L6060, Erskine hydraulic snow blower, back hoe
Feb 16, 2018
146
59
Central, ME,USA
I have the I-match. Started on my JD and is now on my Kubota. I have modified all my impliments to hook up to the quick hitch. I just installed a hydraulic top link this winter. So all I have to get off the tractor for now is to hook up the PTO if the attachment has it. Once you get your attachment quick hitch ready you will really enjoy how easy every thing attaches.
