Cross Battery Cables
cmgreene33
L345DT
Mar 2, 2019
South Hamilton, MA
I crossed the battery cables on my a L345DT tractor when trying to jump a dead battery. I have now bought a new battery and reconnected however I am getting no power to start. Neither the battery charge lamp or oil pressure lamps are coming on. Any thoughts would be appreciated.
GreasedMonkey
Varina,Va
I’m sure it’s a fuse somewhere that’s popped
JerryMT
Jun 17, 2017
528
156
The Palouse - North Idaho
Usually there is a fuse in the circuit that will blow if you do this. (Don't ask me how I know this!) look at the wiring diagram in the owners manual. In my case it was a 40A fuse and was between the key switch and the starter and located on the firewall.
Good Luck.
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
34
Atascadero
After getting the tractor running again, make sure the alternator is charging properly. Crossing cables can sometimes damage the alternator or regulator.
