Removing "trim" on bx23s
Kmcmjmtm
BX23s
Feb 15, 2019
OK
I'm adding rops lights to my new bx23s and I want to mount the switch to the "fender control plastic trim"???. Haven't decided which side yet, but I'm not sure how to remove the trim to run wiring and mount switch. The tractor is brand new and I hesitate to start prying on things cuz I have a tendency to break things...especially trim fasteners and the like. Any help is greatly appreciated. Thanks
5,501
2,208
On the older BX's (BX24/25), there were some bolts under the fender that held the trim down. One of them held the handle to the fender. That one can get stuck.
John T
2017 BX23S
May 5, 2017
1,051
518
under a rock
I mounted my switch inside the little glove box ....
There are 3 bolts holding the plastic box to the fender.
The last one in the rear is a Biotch.
Kmcmjmtm
BX23s
Feb 15, 2019
OK
John T, that's where I was thinking about mounting mine. Have you had any issues with that location?
Thanks guys
John T
2017 BX23S
May 5, 2017
1,051
518
under a rock
Thanks guys
No issues.
I believe I wired it to the 12v outlet juice ... in the box
So the lights go off When you turn the ignition switch off
