Smallest Kubota with cab and gear trans?
PHPaul
Apr 2, 2015
1,024
972
Downeast Maine
www.eastovershoe.com
Just like the title says...what is the smallest (non-BX) Kubota that can be had with both a cab and a gear shift transmission?
Cruised the Kubota site, not looking good until you get into the 50+ HP range which is way more tractor than I could use or afford.
Jchonline
602
Red Feather Lakes, CO
Paul can you please post the issues you are having with the B2650 on OTT? There are a number of folks here that can probably help. To me your issues sound correctable.
To answer your question, I didnt see one available either. Gear in a super small machine is hard. You can probably find an aftermarket cab.
John Deere just announced a 3 series geared tractor at FMS. It is up on their website. Comes in 25HP. https://www.deere.com/en/tractors/compact-tractors/3-series-compact-tractors/3025d/
SDT
multiple and various
Apr 15, 2018
3,251
1,041
SE, IN
just like the title says...what is the smallest (non-bx) kubota that can be had with both a cab and a gear shift transmission?
Cruised the kubota site, not looking good until you get into the 50+ hp range which is way more tractor than i could use or afford.
m6060.
Sdt
PHPaul
Apr 2, 2015
1,024
972
Downeast Maine
6,367
Break down and fix the hydrostat control bearing and everything will work out.
Curious do you think GST means gear drive?
sheepfarmer
Nov 14, 2014
4,449
677
MidMichigan
I don't think you can get a gear transmission, but the quality of the HST in my L3560 is much better and totally different from the B2650. You can get an L3560 with a cab and mid PTO. I don't have either on mine. Only thing is they are a bit big if you want to mow a small lawn or something. Great for mowing pastures etc.
6,367
It doesn't?
If I thought it would STAY fixed, I'd spend the money. Probably will anyway, can't afford a new tractor.
No GST is not a gear shift transmission, it's a Glide Shift Transmission, totally different animal, it's easily said that it's a hydraulic shifted transmission. ;)
eipo
L4060
Dec 1, 2015
693
MI
I saw that. My issue is not related to the NSS. On mine, the "neutral arm" will not allow full range of motion and stops the bearing from sitting in the "neutral holder"
If the "fix" for that is periodic maintenance, it should be in the manual and provisions made to maintain it periodically.
