Anyone Own A L6060 ?
Utopia Texas
Kubota B2650/Kubota L6060
Jun 14, 2017
114
Brookshire & Cat Spring, Texas
Any problems with your L6060 or things you do not like about this unit?
I already own a B2650 and need a larger brother and was wondering about any chronic problems. My B2650 has been great so far.....
SDT
Apr 15, 2018
3,695
1,418
Any problems with your L6060 or things you do not like about this unit? Thanks....
Hydraulic hoses for the third function valve are vulnerable to damage.
Adjustable stop for position control lever is a useless joke.
Front weight bracket (bracket only) cannot be mounted simultaneously with grill guard. Some can.
Not fond of design of hydro pedal but it functions properly.
SDT
Sapper50
L6060, FEL with 4-1 bucket, Top and Tilt, Single tooth ripper, box blade, etc
Oct 10, 2017
32
Ben Wheeler, Texas
I have one
Four in one bucket
3 hydros to the rear
About 220 hours on the clock
I have had zero issues with mine (knock on wood)
It’s done everything + I have ever asked it to do and if someone was looking for this class of tractor (HP, weight etc) couldn’t recommend the L6060 enough
5,675
Awww man ya beat me to it,,I was going to toss another shameless plug you way :D
ken erickson
Nov 21, 2010
1,438
2,671
Waupaca Wisconsin
I stumbled on that site when researching known problems for a friends L4600. My impression when comparing the L4600 page and L6060 is that it is pretty much just identical generic tractor information. Little to none model specific issues or fixes. JMHO
xsf18cdf
L6060 HSTC
Nov 15, 2023
9
Yeah, I noticed the same thing. Looks like an AI-assisted site used for generating clicks.
X
GrizBota
Apr 26, 2023
1,147
733
Oregon
Nice! Are you in any way affiliated with that site?
Thanks
X
Like Ken said, that web site is generic, other than a title with whatever model tractor was searched on. I’ve seen it posted here at least a couple times.
xsf18cdf
L6060 HSTC
Nov 15, 2023
9
Saw the same thing
That's why I asked if the member that recommended it was affiliated with it. It appears to be for generating clicks.
X
GrizBota
Apr 26, 2023
1,147
733
Oregon
Saw the same thing
X
Yup, seems like a reasonable thought process. Although I doubt you will receive a response.
Thomas Talbot
M5-111, lx 2610, l6060 , hla 3000m7040 sold , B2680 sold , bx2360 sold
May 2, 2023
Nova Scotia
I have about 60 hour on L6060. No problems It sa very pwoerful unit for its size. The loader seems well matched for its power and front tire size ... I ran a batwing 16' through heavy hay it did fine although looks silly. M range is quite slow .
troverman
Kubota M4D-071 and Kubota ZD-1211-72
Jun 9, 2015
1,189
268
NH
I'd consider the MX6000 in addition to the L6060. They have the same engine. The MX has a slightly heavier duty front axle and nicer (wider / taller) front tires. The L60 has a nicer 3-point hitch and more 'luxury' features in the cab, although the physical cabs themselves are the same. The MX has better power steering; the HST+ features on the L60 are quite nice however. MX is a little cheaper. I had an L4060 and traded for the MX6000 when I needed more HP but wanted to keep a hydrostatic transmission tractor. I miss some of the L60's features but the MX has been the better tractor platform for me.
Thomas Talbot
May 2, 2023
Nova Scotia
I was down to the wire Mx 6000 vs l6060. My needs were more property maintenance tilling snow blowing grappling chipping etc. so I went l6060 for the transmission and little creature comforts and industrial tires not to rip up the yard in fall and spting . I would say if anyone is doing any farm work, tillage, woods etc as well I would go with the Mx with ag the Mx can do everything I said plus better on the grittier jobs .
