Hello,
even it is not connected to a tractor, I would like to show some pic's about my last project: 3" chipper.
I started with a 6mm steel plate and a circle to cut it with my plasma cutter.
I like the plasma cutter it's like going through warm butter...
I cutted 5 discs which will be the rotating disc. Thickness will be 30mm!
To get them in the shape of a real circle I used the sand belt and rotated the discs.
After and before.
Cutting the windows for the chips
I used a chainwheel with a tapper as the center to fix the disc to the axle.
The chainwheel was shaped at the lathe to get rid of the "chain"
I think this is a good and stable fixing of the ~80 pounds at 2000 rpm.
continued next post
After and before.
continued next post
