Ive been trying to find a installation manual on those to check the mounting points. Because the engine itself is missing s few bolt holes on the side for the bracket it seemsHave you checked the Kubota LA1251 or LA1301?
Kind of like running a FEL on a Farmall M narrow front. Doable (and lots were built) but the pucker factor is very high as is the injury risk from an upset.
Thanks! You da man!LA1251, and you can also get wheel spacers if you want more width.
I'd only flip the rears. You don't get much stability from wider fronts anyway because the axle pivots and it puts more stress on the bearings and such.I widen the tracts by flipping all the wheels around which increased it by about a foot or so. It seems a lot less precarious than the original setup.
