B7100D 4WD 3 cyl. mid 1960's hour meter has never worked
All of a sudden white smoke pouring out of exhaust and immediate loss of power like now only running at 20% of original power. Smoke does not smell like antifreeze, smoke is not pure white more of a dirty white but not dark like oil/diesel burning. Starts good and runs smooth.
What I have done to date with no luck. Fresh fuel, sea foam additive, replaced fuel filter, fuel lines, fuel pump, had injectors rebuilt. Replaced head gasket adjusted valves.
What would you do next? What other questions can I answer for you? FYI: I have not had the fuel injector pump rebuilt or replaced the rings.
Before this happened it ran perfect, with only a little dark smoke that seemed normal for a diesel. Plenty of power and ran smooth. By the way I have owned this tractor for 30 years and the only other problem I have had was to rebuild the starter motor.
