2009 rtv 500
Tundracanam09
Covington,LA
i just purchased a 2009 rtv500 1150 hrs on it. Runs great but the transmission seems to be slipping. all fluids have been changed and are at the correct levels. it takes a few hundred yards to get going. Any ideas would be greatly appreciated
Thanks
5,515
2,226
Your description leaves a lot to be desired, but it sure sounds like it's normal for this model.
Couple things.
First, yes, they are sluggish. And highly dependent on fluid temperature which affects the pressures inside the transmission. It's NOTHING like a car transmission. You shift gears. High and low and reverse those are the only "gears" it has. The speed increases and decreases based on the hydrostatic transmission which is controlled by a bunch of cables that also control the engine throttle.
Honestly if you don't know it's history, I'd suggest a full fluid and filters (there are 2) change. When replacing the transmission fluid, ONLY use Super UDT2 and nothing else. Regular UDT makes them even more temperature sensitive such that on cold mornings, when you mash the throttle, it's like dumping the clutch in overdrive....just kills the engine. Super UDT isn't as bad. But then as the temp comes up, say summer in West Texas, then the engine revs up a lot more and the transmission takes a while to really "catch up". This is a normal characteristic but can be minimized, in other words be made more consistent between temperature swings, by using Super UDT2 fluid-and nothing else (and yes I've tested several kinds of fluids).
Once the fluid and filters are known proper, you can look closer at the cable adjustments-they are very sensitive to proper adjustment per the work shop manual (WSM). VERY sensitive.
Tundracanam09
Covington,LA
Thanks Lugbolt for all the information. i will get the fluids changed this weeked and keep you updated. also do you where i can get a service manual download
OlFerguson
4440, 1120D
Jun 1, 2017
197
12
My 1120 is a bit sluggish , but it always has been. Tranny oil has only been changed once as it has just over 500 hours on it. If you wanted something faster you should have got a razor
OlFerguson
4440, 1120D
Jun 1, 2017
197
12
Every 250 hours for engine oil
Every 500 hours for TXM oil
Grease every 10-15 hours. I usually do 2 pumps per grease nipple
5,515
2,226
That is partially incorrect.
50 hours=trans fluid/filters, engine oil/filter, etc.
Every 200 hours=trans filters.
fluid=every 500 hr after the initial 50hr.
I know these things pretty well and can say with certainty that if anything but Super UDT2 is used, they're gonna be a turd. Well they're a turd anyway, but even worse. And properly servicing them is paramount, as are all cable adjustments being exact (not 1mm off...they have to be perfect).
One issue I see once in a while are that the dowloaded/free manuals aren't updated. If you buy one at Kubota, it's going to be the latest one. WSM's are changed periodically.
OlFerguson
4440, 1120D
Jun 1, 2017
197
12
Yeah, after 50 hours fluid and filter changes for a new machine .
But he stated his was a 2009, so changing your oil and filters after 50 hours is likely a waste of money IF there are maintenance records and documentation is proper. I agree with you partially too :D
Tundracanam09
Covington,LA
Thanks did not have a chance to get to town to get oil and filters going to try on this weekend i will keep you updated
Again thanks for all the information
