How did that happen?Well, really screwed up this time.
Hand slap!
I gave you good advice on how to deal with it, and pressing it out was not on the list.![]()
Send a PM to 007Kubotaguy (Lance) and see if he can hook you up with a new case.
http://www.orangetractortalks.com/forums/member.php?u=11520
Also ask him if he does not have a b6100D diff gear case if he has a New model B7100HST rear diff case, if he does we'll do a swap, as I have a perfect B6100D case sitting here that I was going to use on a B7100HST, The cases are just a tiny bit different, mine would be a direct bolt in for what you need, where for me I'll have to do a little machine work to get it to work properly.![]()
That could be a good deal for both you guys!I will ask him about the B7100HST. He does have the B6100.
Why is only one brake drum sand blasted?
Did you find a powder that matched the blue or just going to try and get close?
I originally wanted to powder coat everything that I could. I couldnt find a powder manufacture that had the Kubota blue. They could do a custom color match but with the cost and minimums i would have to buy it was extremely expensive. also they couldnt guarantee an exact match. So trying to get a match of the blue in the powder and then a match for paint to the powder just wasnt happening. I just decided to go with paint.Haven’t gotten that far yet. Once everything is prepped I will talk to a couple of my local powder coaters to see what they recommend. Need to make sure I can get matching paint. What is a durable paint I should use for the aluminum casings and the engine?
Nice work. Make sure to check your pilot bearing in the end of the crank! I just had to do an epoxy repair on my b6100 pilot bearing( bushing)!
So I could swap in a D950 to my B-6100? Does it need a larger radiator?Yep same motor dimensions externally.
Just bigger pistons, valves and cam.
Note: If you do a D950 with a water pump (there are both style engines out there) you will need to change the radiator fittings and hoses slightly and you will also have to mount an alternator or dynamo on it in a new location, so get a complete engine with dynamo already on it.
Nope, same radiator, in fact you have to neck down the inlet and outlets to make it work with the smaller hoses on the D950.So I could swap in a D950 to my B-6100? Does it need a larger radiator?
Tim
Got any updates?
