Does someone know if and where Hydraulic coupler oil collectors can be purchased without going thru Kubota parts? One can see these equipped on the Kubota M7 series tractors as well as other brands of tractors too.
Just about any good ag store will carry them.Does someone know if and where Hydraulic coupler oil collectors can be purchased without going thru Kubota parts? One can see these equipped on the Kubota M7 series tractors as well as other brands of tractors too.
Here's a link. I've also seen another type but I can't find that link. A guy could make some if he wanted to but they wouldn't be like this type.Does someone know if and where Hydraulic coupler oil collectors can be purchased without going thru Kubota parts? One can see these equipped on the Kubota M7 series tractors as well as other brands of tractors too.
Bad link.Here's a link. I've also seen another type but I can't find that link. A guy could make some if he wanted to but they wouldn't be like this type.
ttps://www.kramp.com/shop-gb/en/1037013/2829522/0/Oil+collectoin+dust+cap++type+TARV
I don't like the " inconsequential" oil dripping down and collecting dirt... but "whatever."Never saw them before and candidly, don't see the need to have them. The little bit of hydraulic oil the seeps out of the coupler when I disconnect (and I do that a lot because every hay tool I use has hydraulic's on them with multiple lines) is inconsequential.
Whatever, however...
Jerry,Here's a link. I've also seen another type but I can't find that link. A guy could make some if he wanted to but they wouldn't be like this type.
Hope you found it usefull-sorry about the link!Jerry,
Your link works - you just left out the "h" on "https".
Thank you very much for helping me!
Mike
https://www.kramp.com/shop-gb/en/1037013/2829522/0/Oil+collectoin+dust+cap++type+TARV
Sounds to me like you need a sportscar, not a tractor. My M's get dirty all the time. Part of what I do. I just wash them off and no, don't wax them or tuck them in to sleep at night either.I don't like the " inconsequential" oil dripping down and collecting dirt... but "whatever."
Contrary to what you think Flip, most brands of tractors have had a variation of these collection systems since the 1980’s. Some use a rubber boot over the coupler that has a little trough with a hose that goes down below the axle and drops the oil on the ground. Newer versions the hose runs into a collection bottle that can be removed to empty once in a while. Just because your tractors and equipment you use in your little hay operation don’t have them, doesn’t mean they don’t exist and aren’t a common item.Never saw them before and candidly, don't see the need to have them. The little bit of hydraulic oil the seeps out of the coupler when I disconnect (and I do that a lot because every hay tool I use has hydraulic's on them with multiple lines) is inconsequential.
