My tractor and I, m9540, are out in a field with cube cart. The situation: start move forward and after say 30 seconds loses power. Stop and idles okay. Very little fuel in inline fuel filter. Shut off tractor fills up with fuel. Took off separator housing removed some trash at inlet elbow reassembled same problem. Also replaced fuel filter, spin on one. Try blowing through fuel supply hose and it is restricted can't hear bubbling in tank. Is this hose plugged or restricted causing this? I look try to see where it attached on tank and I think I have to drop the tank to replace ? Is there a screen in tank ? Expedited response will be greatly appreciated.
