The other solution ive read is to hold the TPL control in the down position either by using a bungee or manually
Now if it is self canceling, holding the valve in a down position constantly with a bungee will do damage as it's going to put the hydraulic system into bypass.
34by151 - if yours is like my BX2360, it returns to a neutral (centered) position, i.e., self-cancelling?
If so, you and Wolfman are both correct.
Best to just hold it down by hand. Easy enough to do, and I find it better for making small adjustments by the "Quarter-inching" adjustment the BX's have. Just pop the lever up/down quickly with thumb or index finger, and the TPH will raise/lower about 1/4".
I would not bungee it in ANY position. You will get accustomed to it quickly. Pretty simple.
I will try to get a pic of my control....again, it's a BX2360, they've been around awhile. Hopefully it's helpful.
If your control looks/acts/ is labeled differently, post a picture of it. (You need 5 posts before you can post photos)
