Im getting ready to rebuild an l245dt and had a few questions. I see the axle shaft for the front wheel drive seems to go right through the oil pan. What's the easiest way to split and remove the engine on these tractors?
I purchased
46mm socket
(3) 76mm pistons
(3) sleeves
(1) sleeve puller custom made (79.40mm od 74.80 id disc)
(3) ring sets
(3) piston pin bushings
Main bearings and seals
Thrust bearing
Rod bearings
Upper gasket set
Lower gasket set
Head gasket
Oil cam plugs (Has no oil pressure)
Am I missing anything? I'm going to have a shop magna flux the head and bore the block to size after sleeving.
I purchased
46mm socket
(3) 76mm pistons
(3) sleeves
(3) ring sets
Thrust bearing
Rod bearings
Upper gasket set
Lower gasket set
Head gasket
