After more research and seeing tons of videos of B series tractor and implement use on properties similar to mine I'm starting to think that a B series may be sufficient, maybe a B2650. Getting work done quickly isn't my priority so if I need to make a few extra passes with the blower or trips with gravel/dirt I don't mind, I'll have the time.
From what I've seen there isn't much the B series can't do for my requirements. I just didn't think initially they were as capable as I'm now discovering. A smaller tractor would also be more nimble in the woods which is my second priority after snow removal.
The B2650 was one machine I seriously considered, but I ended up with the L4060. There are a lot of B2650 owners here that are very satisfied with this model.
Since you’re looking at the larger B series machines... make sure you do your homework on the B3350 in particular (new or used). The 3350 has been plagued with dpf problems. There was talk of a redesigned B3350, but I highly doubt it’s out yet.
