Looking for a little advice and help with purchasing a tractor.
My application:
13 acre property
primarily hilly wood lot
1 km gravel driveway that needs to be plowed in winter/graded in summer
My first priority is snow removal and with the length of the driveway I'm leaning towards an inverted blower. I have some portions where the grade is 12-14 percent so I'm guessing I'll need chains and loaded tires. We're in southern Ontario and can get significant snowfall. I also will grade the driveway, clear brush, move gravel/dirt, lift logs for cutting firewood and prepare garden beds.
My thoughts are somewhere between a 35-50 HP tractor with inverted snow blower, FEL, box scraper and pallet forks.
The local dealer put a quote together for a new L4060 HST with cab, industrial tires with FEL (LA805), box scraper (Kubota 1572 fixed bar), pallet forks (Walco 2000 lb) and Normand N82 260 inverted blower. Total tax in around $56K.
This will be our retirement home for the next 25 yrs so it may be worth going new. I'd be prepared to go used but haven't really seen what I think I want/need.
I'd appreciate thoughts on HP range for my intended use and also on buying new vs used.
Thanks.
My application:
13 acre property
Thanks.
