Hand Controls for a L2501
BigG
Sep 14, 2018
1,953
774
West Central,FL
I purchased a new L2501 HST in August. I took a pretty bad fall onto my knees in September and it is looking like it will take months to get my knees replaced. I was wondering if anyone has any information for a hand control that could be used for the HST pedal. Most of the information I have found on the web is of little use or out of business.
Thank you
Poohbear
Jul 6, 2018
560
205
Gilmer,Tx,United States
Sorry for your knee problem. I had one replaced last year. As an owner of bad knees myself I must ask if you can't use the HST pedal , how are you going to get on the tractor ? Time to teach the Wife or good friend how to,operate till you recover. Not pickin on ya , I know way too much about bad knees.
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
Must be awful to have a new tractor and not be able to use it! I don't know of any companies per se, but I have an old Ingersoll garden tractor, and it has for me the annoying feature that everything is done with the hands, throttle, forward, reverse, hst, steering, everything. Perhaps something from its design could be borrowed. Everything is cable controlled. Getting on your tractor might be the best physical therapy. I am a strong proponent of pt, it really helps, even if it just keeps your muscles strong for surgery.
11,005
The cost of a custom device would most likely make it impractical! ;)
dlundblad
G5200, L2501, ZD1211
May 16, 2009
504
IN
You could add cruise control that will put a lever right next to the seat. Should be about $150-$200 from the dealer.
Won't help you with reverse though.
5,255
1,057
Thank you
An option to consider would involve the use of a 12 volt linear actuator.
The actuator could be mounted vertically and secured to the HST pedal with a ball joint. The actuator, at the push of a switch, would move the HST pedal up or down. The actuator action will be slow which is what you want.
https://www.northerntool.com/shop/tools/product_200520510_200520510
It could be controlled with an electric controller like this one.
https://www.northerntool.com/shop/tools/product_200520502_200520502
Kennyd4110
Vendor Member
Sep 7, 2013
1,515
901
Westminster, MD
www.boltonhooks.com
With all due respect Dave, that is incorrect and even dangerous. You’d want very fast (but accurate) action so it could return the pedal to neutral quickly when you need to stop. Waiting even one second would be an eternity in an emergency situation. I’ve never seen a linear actuator move fast! There are industrial servos that could be used, but those require special controllers and are both very expensive.
5,255
1,057
I see the key switch as the emergency button. I accept your criticism but then propose a solution the average owner could afford otherwise the owner is left with nothing.
He could always completely automate his tractor and run it while sitting on his front porch :).
vic gerbasi
M110 L3300
Feb 19, 2016
232
dugald mb canada
L3300 GST HST - set the gear [ speed] you want ] set the throttle -rpm] you are done. move the forward reverse lever to neutral and bingo you have stopped motions.
hope this helps i was on mine yesterday moving a foot of snow for me and 4 neighbors
11,005
Vic,
Sounds like you have a GST and not a HST.
HST's are foot pedal operated where GST's are hand shuttle operated. ;)
Big Gee Tn
L2501
Dec 12, 2018
40
White Pine,tn
This may be too simple thinking on my part,but could the pedal be removed and a simple piece of flat bar bolted in its place to make a lever forward/reverse? Full speed of hst might not remain but at least the tractor could be used,not in a speedy process using loader but it would be usable at least and not be permanently modified so you could put it back original when you are healed up.
TripleR
Sep 16, 2011
1,911
SE Missouri
There is an old thread on TBN where a paraplegic equipped his foot control by attaching a rod to it, I saved the link to it for a while. It looked pretty simple.
