Looking at getting a MX5800HST for moving round bales on the farm. Does anyone have any experience with this? Big round bales, likely 1500-1800lbs.
Thanks in advance!
Thanks in advance!
I'd say a 4x6 at maximum density. Only one that I know of that makes a 5 wide round baler is JD and it's an an odd size.. Reason being is you can transport 4 wides x 2 on the road with no problem but 5 wide x 2 becomes a big problem because 120" wide is a permit load. I know someone who got a ticket for just that.How high do you need to lift them? 1800 is a stout bale! 5x6 I am guessing?
The LA1065 loader is rated for 2200 lbs max height at the pins...but with bales you are usually quite a bit forward of them so it will be less.
If you need to stack 2 high, it may be an issue.
Also why pay for the extra HP if all you are doing is moving bales? The loader lift capacity is the same on the 48, 52, 58.
Also consider rear ballast (3 pt spear or something to counter the weight out front. At 1800 lbs you are close to the max capacity and dont want it to be tipsy.
For those size bales, I would probably be looking a size up (M5660 or M6060). You get a heavier tractor and more lift capacity.
All great points. Would you also recommend the M5660 or M6060 at a minimum?I'd say a 4x6 at maximum density. Only one that I know of that makes a 5 wide round baler is JD and it's an an odd size.. Reason being is you can transport 4 wides x 2 on the road with no problem but 5 wide x 2 becomes a big problem because 120" wide is a permit load. I know someone who got a ticket for just that.
The MX5800 isn't enough tractor or loader for moving large rounds around, rear ballast or not. I wouldn't even consider high density 4 x 4's. Remember with a bale spear the bale weight is well outboard of the pivot point.
I wish.... Last year I ran 600 rounds and kept 20 for my stock and sold the rest. I have one customer that takes everything I make. I call him when I'm done bailing and have the rounds lined up in the field. He brings in his goosenecks and flat beds and drops them for me to load. I load them up, he straps them down and hauls them away. Pays me at the end of the year, good as gold.I have moved bales with my MX5200. Most have been 4x4 or 4x5.
I don't go through a lot, nine this winter I use a mix of round and small squares for my sheep.
Sent from my Pixel using Tapatalk
I have an MX5800 and my farmer that baled my property left my share of 11 in the field. They were 5x6 very tightly wrapped bales. I could not pick up one without having one on the back for counterweight. They put a lot of load on the loader. I could pick up but once in the air, tilt function did not work with the weight. This was at +2200 RPM. The best way I moved them around was with the 3 pt spear on the back. Very capable there for sure. But as far as on the front it would make your butt pucker going through uneven terrain on the field. My best guess was the bales were +2000 lbs. Hope this helps. Other than that it has been great with any other tasks.Looking at getting a MX5800HST for moving round bales on the farm. Does anyone have any experience with this? Big round bales, likely 1500-1800lbs.
Thanks in advance!
I have a MX5800 too and can move and double stack 2000# skids of wood bricks and pellets but like mentioned above it's at it's limit doing so without a substantial amount of counter weight on the 3 point. The MX5800 is a great machine for mowing and pushing snow around but a little light to be moving bales I'm sure.I have an MX5800 and my farmer that baled my property left my share of 11 in the field. They were 5x6 very tightly wrapped bales. I could not pick up one without having one on the back for counterweight. They put a lot of load on the loader. I could pick up but once in the air, tilt function did not work with the weight. This was at +2200 RPM. The best way I moved them around was with the 3 pt spear on the back. Very capable there for sure. But as far as on the front it would make your butt pucker going through uneven terrain on the field. My best guess was the bales were +2000 lbs. Hope this helps. Other than that it has been great with any other tasks.
Depends on RM and how much hydraulic pressure I put on the density control cylinders. I have continuous readout for RM via a Delmhorst moisture meter with sensing shoes in the bale chamber. I like to roll in them so they are tight but not so tight they cannot breathe a bit. The tighter the roll (and the tighter the net wrap, the better they handle. Like I've said before, I never weighed them but I imagine around 1200 pounds average.Flip, what's the density of the bales you're selling? They end up at 1000#, or are they lighter?
None of your posts answer the question of the OP about using a MX5800 for moving hay bales. You need to stay on target and keep post in threads to what the thread is about and stop going on a rant about something that makes you feel good. Start your own threads.I need big equipment because I'm usually under the gun with the weather anyway. Least I don't need 300 horse fuel guzzling tractors, the M Series Kubota's are just fine. I'd like to have a new 135 horse Kubota but I don't like the tier 4 deal at all. My 2 are pre tier 4 emissions as well as the JD I have my eye on.
Learned rel quick about the Tier 4 final engines. Watched the guy down the road with his big JD in the field, derated and JD trying to fix it. Went on for a couple days until they brought out a loaner and flat bedded the other back to the dealer.
Not my thing at all and my pre-tier 4's are holding their value quite nicely if at some point I want to sell out.
I treat my tractors better than I treat my wife or so she says.....
