L3130 tie rod boot
Bebo12249
M6800 L3130 ZD326
Dec 28, 2018
Canton, MS
I just bought a 2005 L3130 with loader. The boot on the tie rod is split on one side. I assume that like a car, this needs to be replaced. Is this a repair that a DIY can handle? And if yes or no, if the front tire ever needs to be raised, is this a matter of jacking the front end while lowering the bucket? Thanks for any comments. Bill
jonmad
BX2380
Jun 7, 2018
Lebanon
There is a YouTube video of exactly this but it’s on a BX model. Should be similar. Doesn’t look to be difficult.
3,316
Mine was torn by the PO and I just cut it off and wrapped the joint with two-wraps of neoprene gasket material and clamped it on the ends with safety-wire. It keeps out the dirt and has worked just fine for some time now. (If you do this, I suggest you leave the last wrap-edge on the under-side, and also have it face aft.)
dlundblad
G5200, L2501, ZD1211
May 16, 2009
503
10
IN
If anyone knows how to work that ring spring thing (part 070), please share.
200mph
Mar 3, 2017
1,228
61
PA
I walked it off using a screw driver. It's just a spiraled springy wire. It's somewhat similar to putting a key on a key ring.
It is easy to get off, but somewhat of a pain getting back on.
dlundblad
May 16, 2009
503
10
IN
Maybe we didn't try hard enough. Dad and I gave up on reinstalling them and just used black zip ties.
200mph
Mar 3, 2017
1,228
61
PA
Curious how much grease was in the joint when the boot was removed.
