B 8200 WTB stabilizer bars
hunter.b2015
17
Batavia
Just picked up a b8200 and I’m looking for a set of stabilizer bars for the 3 pt. Looks like they have broke and been welded over the years.
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
I had the same problem for the most part. Mine were bent up pretty good. I couldn't turn them at all by hand and it took a good size wrench to be able to pry them around and that took forever.
I did this to my (now sold) B8200....
http://www.orangetractortalks.com/forums/showthread.php?t=34677
I cut off the old stabilizers from the axle side clevis, and re-used that clevis on the new stabilizers.
I sourced parts from here....
https://www.hoyetractor.com/
mickeyd
Mar 21, 2014
1,192
Guin, AL
I got my Stabilizer bars from Hodge here on OTT.
They are outstanding and very well made.
SRG
Jul 15, 2017
490
N. IL
Unfortunately, he doesn't make the fantastic telescoping stabilizers for the B8200 because there isn't enough room and the B8200 requires too short of a stabilizer for the outside position. I have consulted him on this. I was disappoint.
coachgeo
Nov 16, 2012
2,460
35
Southern OH
Hopefully Blown has what you need ... otherwise
Have you checked the Ultimate Sticky at top of this forum? Would behove you to do so for there are links in there that will take you to info about where to get used parts and implements...... also where to get aftermarket parts and implements; as well as other information/links
