I’ve got a m5-091 cab tractor and it’s got about 220 hours on it. Since September it has only had 11 hours put on it. In September we got a check engine light and dealer replaced the harness and a relay. Fast forward to a few weeks ago I used it and got a code again. Another relay replaced. Put 1 hour in it and got a def fluid contamination code. They said the header unit was bad. Luckily i found another dealer with one in stock.
Got it fixed Friday and should be able to put some hours on it Thursday. Is this going to be the norm? Might end up getting the extended warranty on it. It’s used for mowing, disc, and roto tilling.
