Top link sizes
mayyear
B2910
Apr 20, 2018
Lodi California
Hello!
I have a problem and I'm hoping someone else has had the problem too!***128514;
I recently added some Pat's easy hitches which are amazing...but now my top link (hydraulic) is too short and I cant get any of my implements level :( now I have tried looking for longer stroke top links but I cant seem to find them anywhere! It's a category 1 link and my current one has an 8 inch stroke. Does anyone know a company that sells larger category 1 links???
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
643
256
Herald Calif.
Hello
If your hydraulic top link is in good condition, I would just have it extended. Ag Industrial manufacturing in Lodi could take care of you.
Good Luck Lance
majorwager
MX5100 FEL ford 1620 FEL International 484 FEL Lull 844C
Top link adapter agri supply
Longer cylinder: just use a swivel eye cylinder from surplus center. Many length and rod diameters available, inexpensive.
Existing rod could be replaced w/ longer rod that would NOT retract completely. That is a very expensive solution.
I had pitting on a rod, asked hyd shop for quote. Replacement rod was more than whole new cylinder.
MtnViewRanch
796
233
Lakeside Ca.
Hello!
So you need a cat 1 top link with a narrow (1 9/16") tractor end with a 20"-30" working length. I can build it for you, but I'm out 19 weeks right now. ;)
