When my B21 is in 4wd should either axle lock? I wonder if it ever did, it doesn't now.
What do you mean by either axle “lock”? Rear axle would always be engaged but both rear tires wouldn’t spin at the same time without the diff lock engaged.Front would be the same except no diff lock on the front. Are you looking for all 4 tires to be spinning the same if it’s stuck?When my B21 is in 4wd should either axle lock? I wonder if it ever did, it doesn't now.
Thanks for sharing the pictures. These little B TLBs are just amazing for their size. I almost bought a B26, but decided on moving up a few sizes for my acreage.Thanks, Front spins. I have a steep asphalt driveway and run chains in winter. I just wondered if front was limited. I have never had it back to the dealer, always try to do my own maintenance. This has just been oils and filters. I did wear out the front tires. 1100 hours. The last couple years it has been used more as a skidder than a tractor.
Nope, it really is 4x4. Power "has the opportunity" to flow to all four wheels. It's not like it defaults to one particular wheel in the front and one particular wheel in the rear....People buy 4wd vehicles and think they are when in reality they are 2 wheel drive (one wheel front and one wheel rear).
No. In an open differential without a limited slip clutch pack, power delivery tends to go to the wheel that is slipping the least.Nope, it really is 4x4. Power "has the opportunity" to flow to all four wheels. It's not like it defaults to one particular wheel in the front and one particular wheel in the rear.
Power always flows to the path of least resistance through an open differential. That means if all your tires are sitting on approximately equal tractive surfaces, power will actually be sent equally out. The minute one wheel gets on snow or ice or sand or whatever surface has less traction...then, at that point all the power will flow to that wheel. Using part-time 4x4 like on a pickup or tractor, power is forced to the front and rear axles, but from there it will go to whichever side is easier to turn unless they are both about equal.
That's not correct. Power will always flow through the path of least resistance. So in an open differential scenario, power will tend to go to the wheel that is slipping the most.No. In an open differential without a limited slip clutch pack, power delivery tends to go to the wheel that is slipping the least.
Why lockers are built and why limited slip is a factory option.
In my case I run an ARB Air Locker in my front diff and a Detroit Tru-Track in the back on my pickup truck.
Thank you...??? If power went to the wheel slipping the least, you wouldn't need lockers. It ALWAYS goes to the path of LEAST resistance.
Sent from my LGMP260 using Tapatalk
I don't believe he was supporting your side...Thank you...
They really do have 4-wheel drive. If you lifted a tractor so all 4 wheels were off the ground, engaged 4x4, and put the tractor into gear (or pressed the forward HST pedal)...all four wheels would be spinning. The action of the differential is what causes loss of traction when on surfaces of unequal grip....so the absolute best a tractor (B -BX) can ever have is three wheel drive!!!!
This has been discussed on several occasions.......
a tractor.....B series, BX series can only have 2 wheel drive .....yes 2 wheel, even when in 4wd !!!!!! How many times have you been on a slight incline where one rear is slightly off the ground and the opposite front is off the ground?????
THE free tires are spinning at a rate that is twice the rate if you were going in a straight line! SO .......
now you say - I am going to lock the rear diffy ............BOTH rears will spin at the same time and the same rate!!! That little ol front tire is still spinning at a larger rate than normal ,UNTIL the traction is regained on the front end, thus both fronts will pull.
Now some bigger machines DO have diffy lock on the front end and the rear....that will result in 4 wheeeeeellllss going the more or less same ratio and rate. I have never used a tractor with diffy lock on the front.
On a car ......2wd on ice one tire.....that tire spins - due to the least resistance - or the least amount of friction - and ....it spins twice as fast as normal!
In the old days - you were told to apply the brakes a wee bit to stop that from spinning a hopefully the easy spinning tire will slow down and the tire that has friction to the ground will get some of the rate of spin.
Now before people chime in on clutch packs and computer controlled rear ends......
we are talking about the tractors .......B - BX and maybe the L's and M's......
remember we are NOT talking about linear track subarus!![]()
