BX25-D Bucket Curl Cylinder broke.
2,644
The failure mode of the one BX cylinder I have seen was not a broken piston, but rather all the threads ripped off the piston end of the ram. Cost of the ram from Kubota was higher than the price of a new cylinder, and making a new ram from scratch was even higher, according to the local hydraulic shop. I was asked to turn the damaged ram down & re-thread to a smaller size, then alter the piston to fit. I was able to convince the owner that if the original failed, a smaller one would not last long. He bit the bullet & bought a new complete cylinder.
Having said that, I think the broken piston failure is much more common.
If I owned one & had this failure, I would probably machine a new piston from a stronger material, like SS. Not sure where that would shift the failure point to, (the threads?) but I'll bet the piston wouldn't break again.
Flienlow
Kubota BX25D, Kubota U25 mini EX, SVL75,Landpride Grapple,Landpride grading scra
Mar 9, 2015
352
snohomish
My piston had a "small" break. :)
here is s a few shots I took during the project.
https://www.youtube.com/watch?v=NJ67gTtyBSw
(and sorry, I cannot film, talk, and think at the same time.)
2,644
Not with proper wear rings. Piston should never touch the bore.
