johnjk
I finally got a free Saturday to work on my B3200. Did an oil/filter change and installed a set of front and rear Bro-Tek Wheel spacers. The product is really well manufactured and came with everything needed minus some red Locktite. Richard at Bro-Tek was quick to respond to questions as well. The instructions were well written and it took around 20 min a corner to get them installed. No photo's of the front since I forgot and the spacers are hard to see when the front wheels are on. The only change I did to the instructions was to use an impact wrench to remove the nuts/bolts to remove the wheels. I was a bit hesitant on the rears since they are loaded and quite heavy. No issues at all with being able to get the wheel off and prop it against the wall. Going back on was easier. Just rotate the hub by hand to line up the studs, get the wheel in position and start the lug nuts over the washers and lock washers. Hopefully we get enough snow this week to run her around and play for a bit. Will recheck the nut torque post play as well.
