Quick Hitch
mo old mike
L2501, Land Pride attachments
Nov 16, 2018
Central Missouri
Hello all.
New here but been looking 3-4 times a week since I bought my L2501 in August of this year. Sold my last tractor 25 years ago.
This forum seems like a nice knowledgeable group of guys.
OK now for the help request. I am getting too old to push,pry, and kick around on 3-Point hook up. I'm going to buy a Quick-Hitch.
Have seen recommendations here for about every kind made but I have it narrowed down to 2. Both available local. Not messing with ordering.
1) Land Pride QH=10
2) JD I-Match
Both Cat-1 Do NOT want to mess with bushings. Any new purchases will be QH compatible.
Dealer wants $550 for Land Pride. $300 for JD I-match.
Big difference. I'm thinking I-Match (Paint will be required)
Will the I-Match work as well as Land Pride ?
Thanks for the help
Mike
majorwager
MX5100 FEL ford 1620 FEL International 484 FEL Lull 844C
PAT's quick hitch system W/ Spreader bar offers infinite width adjustment. Not so old yet, that connecting the top link is an issue. $169. W/ Amazon free shipping till Dec. 25. Many implements require separate PTO connection anyway.
EDIT: Mike, I can attest, if PAT's system is installed correctly, they are rock solid.
Sammy3700
Feb 20, 2012
437
41
Red Springs, NC
Second the Pats I made my own ridged stabilizes or you can look at the ones Hodge makes
mo old mike
Nov 16, 2018
Central Missouri
Thanks for the reply.
Top Link is not an issue..I agree. Have the PTO Shaft to attach no matter what you get.
Looked at Pat's and watched the videos. It did not seem as solid as a QH. I have never seen one (In the Wild) to compare. Pat's definitely has an advantage with several kinds of attachments but I sold everything with the old tractor and now all my attachments have the QH label.
Will give Pat's another look
Mike
Sammy3700
Feb 20, 2012
437
41
Red Springs, NC
I bought the weld ones and made new lift arms exactly same length as original with Pats welded on. Forgot to mention this earlier. Do not know how to post pictures on here but will be glad to text you some.
edritchey
A bunch of cute little Kubotas
Jul 19, 2014
1,106
804
Wellsville, PA
I bought a Land Pride QH15 from a local dealer for $375 that price you got on the QH10 seem really high. Several other members here say they use the Harbor Freight QH and it works great for a 100 bucks or less.
Missouribound
Jun 17, 2014
652
42
Missouri
I bought a quick hitch a couple of years ago. I use it for my box blade and counterweight. Unfortunately if I use it with my PTO finish mower on some steep inclines it will bind up the driveshaft. I suspect this is a problem common on most quick hitches since the design is nearly identical across the board.
Other than that it does what it needs to and makes the hookup much easier.
......Unless it's a PTO implement where it puts yet another thing in the way.
5,193
Is JD I-Match proprietary for it's dimensions...i.e., not a "standard" Cat 1 QH? Means you end up with JD implements to match it?
Seems there's something rattlin' around in my old noggin'...and I may be wrong. Maybe some guys here can affirm or correct me. Just something to check on.
I have an $80 HF and it works fine. I think many low-end QH are from the same place.
Lot of guys like the Land Pride too. I remember the LP QH15 is much better than the 05 or 10 models, like the one Ed Ritchey has.
Poohbear
Jul 6, 2018
501
154
Gilmer,Tx,United States
I have the QH10 on my L3301 and also have the Kubota toplink kit. No issues BUT I only have Kubota LP implements for the 3point. LP says all of their stuff works on their QH.
That price is more inline with the larger QH15.
torch
Jun 10, 2016
2,619
869
Muskoka, Ont.
I have the HF unit too. It works, but it is sized for Cat 2 pins. Rather than bushings, I just formed a short piece of 1" flat bar into a U shape and welded it in place. Repeat on the other side. Now I don't need bushings. :D
Whatever you get: HF, JD, Pats, etc. bear in mind that they all add 3 or 4" to the effective length of the arms, so potentially more strain on things and existing driveshafts could be too short, or at least, dangerously over-extended. Measure carefully.
sheepfarmer
Nov 14, 2014
4,449
677
MidMichigan
Yes same problem here with flail mower. Need a few more inches of clearance for going over uneven ground.
Wbk
307
St Adolphe Manitoba Canada
I have 3 of the Northern Tool quick hitches, the only thing that I don't like about them is the top hook because of the way they make the adjustment bracket too wide it interferes when your hooking up. I found one made by a company called Agri eeze with a different set up and is much more user friendly. What I ended up doing is cutting off the system mine had and making it similar to there's. So I guess what I saying is if your implements have a narrow top hook bracket be careful which unit you buy. Good Luck
ipz2222
L235, bx2670
May 30, 2009
1,927
32
38
chickamauga ga usa
And the most annoying thing is no standardization. When I bought my qh, it only fit one of my attachments, all the rest had to be slightly or major modified. Some were 1/2 too wide to fit the qh and some were 1/2 too narrow. At least now , they all fit. The only one I have to get off the tractor for is the rotary cutter, to hook up the pto shaft.
ipz2222
L235, bx2670
May 30, 2009
1,927
32
38
chickamauga ga usa
Forgot to mention, what I didn't know at the time I bought my first tractor was, all the pins, top and bottom, are different diameters from cat 1 to cat 3. Tractor supply has a chart above the parts bin for clevis pins and pto shafts. I took a picture of it for myself.
SidecarFlip
Banned
554
Hello all.
1) Land Pride QH=10
2) JD I-Match
Thanks for the help
Mike
When you get to be my age, just getting into and out of my big M's is a chore...:D
I third the Pats system. I looked at a all sorts of QH designs and Pats looked to me to be the best and I use it hard. I'm Cat 2-3 and everything I hitch is either heavy or pulls hard. Never had any issue. I don't use the spreader bar. My sway links are designed to slide adjust.
One nice thing about my tractors is the end links telescope so I can unlatch them with the Pats and they allow about 4" of movement to get hitched.
Believe me, if it can be broken, I can break it.
SidecarFlip
Banned
554
I have a JD Haybine and I left it green, I'm colorblind....lol
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
Columbia, CT
I added a HF Quick Hitch to my BX earlier this year - best addition so far!
I bought the Quick Connect bushings from TSC for $29 for my Carry All that I use the most. For the rest of my 3 point implements I just use cheap $3 Category 1 to Category 2 bushings/sleeves
That being said - I currently have no rotary/PTO implements, so I don't know how it effects drive shaft length on a PTO set-up...
Mainah
L2501HST, BLMX3164 blower, BB1266 box blade, BX42S chipper, Titan forks
Feb 26, 2018
100
Standish, Maine
I bought a Speeco which is the same as the HF one I believe. It sure beats wrestling with 3 pt arms and heavy implements when you just can’t anymore. It does add to the challenge of connecting a pto shaft but it’s still easier overall imho.
3,545
2,001
Ive got the speeco QH as well but it doesnt fit all implements nicely. The price was right at the time but I wouldnt buy one again.
The top link is always going to require fiddling because it seems to be in a different position on all my implements.
I would consider buying the Pats quick hitch style to replace the speeco if I see them go on sale again. That and top-n-tilt.
