Have a ZD21-60 mower that I was mowing with yesterday afternoon. This mower is 6 years old but has less than 400 hrs. not used commercially. Has been serviced regularly by my Kubota dealer. Engine stalled while mowing and now after checking all fuses including the slow blow 40 the ignition glow plug will not light up, other 2 lights are bright red but will not turn starter over or heat the glow plugs.
A similiar problem came up in May of 2008 my dealer did a PTO switch service, brake lever lock, they replaced a#30-K3511-55620 switch I'm not sure if this is the PTO swtich or one of the other safety switches. Does anyone know of anything else I could check before hauling mower in to my dealer? I know that there is probably a single check wire on the unit that will disconnect all safety swithes just to check the unit to see if the shortage is in this circuit does anyone know where it is located?
Any help will be greatly appreciated.
James
James
