Snow Blade
terntees
bx2360
Oct 20, 2017
stewartstown, pa
I recently bought a BX2763A snow blade for my BX tractor. The instructions have a piece to mount to the back of the blade to make it rigid so it does not flip forward if you hit something while plowing. Is there an advantage to plowing with this bracket in place so the blade is rigid or should I remove these brackets and adjust the spring tension so it tips forward?
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
You're going to come to a really hard/abrupt stop if you leave it rigid and hit something. I think that is to use the blade in a similar fashion to a dozer blade. For plowing snow, I'd leave the brackets so it isn't rigid.
4,305
X3 - like a pickup plow, you want it to tip doing snow.
Put the bracket back on for dirt/stone.
