Smoke from brown tube
rgoodson
B7100 HST
May 26, 2011
Vacaville, CA
Just got done mowing for about an hour and when I stopped I noticed a lot of smoke coming out of a tube on the left hand side of the engine. The tube wasn't connected to anything it was pointing straight down to the ground. Not sure if this piece is supposed to be connected to anything or if it's supposed to just hang the way it is.
I am kind of new to the tractor as I inherited it from my father-in-law B7100 HST.
Marty394
L3010 w/ Cab, RCR 1560, RB 1584, SMC Loader, KK II 60" Gear Drive Tiller
Feb 28, 2010
86
Wisconsin
Not sure, but it sounds like the draft tube to me. If it is, it is the vent for the crankcase. If it was being worked hard there could be some "smoke " coming from the draft tube.
Bob
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
I agree with Marty, Sounds like the Draft vent, If it is then it is probably connected to the valve cover, It allows combustion gasses that get by the rings and enter the base of the engine to escape, On older pre 1961-62 cars they were called road draft tubes, They faced downward and the idea was that combustion gasses were siphoned out of the crankase as the vehicle travelled down the road, If gasses are not vented then the engine base would eventually become pressurized from normal ring blowby and possibly blow you pan gasket, Road draft tubes were replaced with PCV Valves(Positive Crankcase Ventilation) which basically is a vacuum line from the intake that sucks off the base gasses and directs them thru the manifold to burn them during the combustion process reducing emissions and creating a closed loop for Positive CrankCase Ventilation.
The tube as it is called is a draft tube to reduce base compression so it would be normal to see some amount of escaping gasses coming from it including an occasional small drop of oil, More when the engine is being run at higher rpms or working hard,Excessive smoke/steam/gasses accompanied by dripping oil indicates excessive base compression caused by worn rings or broken rings,blown or leaking head gaskets.
Excessive dripping of oil without excessive blow by can be the result of clogged oil galleries causing the valve cover to fill with oil and escape thru the draft tube
If the smoke occurs for more than a few seconds after the engine has been shut down it could also mean that the engine is running hotter than normal causing the oil on the inside of the engine to smoke or steam from contact with the hot metal engine parts
ipz2222
L235, bx2670
May 30, 2009
1,927
32
38
chickamauga ga usa
morningstar, that was one good hi tech explanation. Let's get together and talk about the ramifacations of intergalictic travel through gamma ray polarized belts. (BG)
asbug
B7001 - looks orange to me... Woods 5' scrape, 42" rotary cutter, shreader/chip.
Feb 11, 2011
155
Varnell,GA - USA
Freakin' A....
I work in Chickamauga!
We should get together one day and meet!
KC
cmorningstar01
Mar 27, 2011
341
81
Pemberton NJ USA
Yep..state of the art for 1961 CARB and 1962 National emissions standards
Freakin' A....
KC
Hmm...I live in Pemberton NJ but ipz2222 is from Chickamauga...Wait...maybe I could use the gamma ray polarized belts for some interstate travel.
Seriously guys...Thanks for the compliments.
Val(as in Valerie)....oops maybe I should not have mentioned that little detail:eek:
gurn
Kubota L175
Apr 15, 2011
239
14
Nashville,Tn
It's much easier to just use the Stargate system :D
