B2601 how much ballast? I need to make a ballast box for winter. What does Kubota recommend for weight?
I am plowing snowB2601 how much ballast? I need to make a ballast box for winter. What does Kubota recommend for weight?
Here are the spec's for the 3 pt hitchI am plowing snow
That makes a lot of sense. You really aren't lifting with a plow and putting any stress on the front axle. Even a bucket full of snow is relatively light compared to dirt or gravel. Traction is the biggest issue, not counterbalance.I actually prefer to plow without any ballast.
Assuming it's a standard mix, it will be right around 700# if filled to the top.A little off topic but a friend gave me an old rusted ballast container made out of a 55 gallon drum (cut down to about 20 inches +/-) filled with concrete and pieces of lead imbedded in the concrete. He does not know what it weighs. Any suggestions on how I can determine it's weight? I searched "crane scales" on google but can't see buying one only to use it one time. Thanks for any suggestions.
Heavy rear blade is where I would spend my money. So many uses. In the winter, you can blade or back drag snow. I am planning on just the front bucket and the rear blade. We will see how it goes!I also needed a ballist box, but after looking into it that’s all there good for. I ended picking up a rear box blade that weights about the same as a box and now I have something I can use also. If you don’t need any other attachments a box may be the way to go but down the road you may need a rear blade of some sort.
