J john wilkerson New member Equipment M8200,M6030,M5030,M4030,B2400 Oct 4, 2018 3 0 0 defuniak spgs florida Oct 4, 2018 #1 LA1251 loader, ser #10391, Control valve sticks in the "going up" position and will not stay in "float" position.
L lugbolt Well-known member Equipment ZG127S-54 Oct 15, 2015 5,205 1,889 113 Mid, South, USA Oct 4, 2018 #2 Detent assembly failing in the valve?
NoJacketRequired Active member Equipment B7510 & LA302 FEL & B2782 blower, B7510 & B2781 blower, B2410 & B2550 blower May 25, 2016 432 68 28 Ottawa, Ontario Oct 4, 2018 #3 There are several threads here talking about moisture in the valve causing corrosion of the spring ball assembly as the cause of loss of float function. "Search" is your friend! LoL
J john wilkerson New member Equipment M8200,M6030,M5030,M4030,B2400 Oct 4, 2018 3 0 0 defuniak spgs florida Oct 5, 2018 #4 lugbolt said: Detent assembly failing in the valve? Click to expand... Thanks, I will order one up and hope to be able to install it.
J john wilkerson New member Equipment M8200,M6030,M5030,M4030,B2400 Oct 4, 2018 3 0 0 defuniak spgs florida Oct 18, 2018 #5 Ok...installed the new "detent kit". Still no "float". What next please?
