Hi all - thinking of getting a compression and leakdown test on my S2600 engine so need to remove glow plugs or injectors.
Question: which is less risky? Remove glow plugs, or remove injectors? (People with the same series engines - Z751 Z851 DH1101 D1301 V1501 V1701 S2200 S2800 may know the answer to this).
Would be great to get your opinions, thank you.
- Removing glow plugs sounds simpler but are they prone to breaking on these engines? Do I have to pull the cylinder head off if a glow tip plug breaks?
- Removing injectors - need the special tool with a slot cut out for the return lines - I can easily make the tool myself, but do I have to first loosen the nut that holds the "eye tube joint"? In which case I'm disturbing the copper washer, so I would need to pull the injector body apart and anneal the copper washer. (In addition to removing the fuel lines to the injectors - risk of dirt getting into lines or injector etc.)
- I believe some glow plugs are hard to get at - so maybe it would be less grief to remove the injector on those cylinders. Would it affect the results if say one cylinder was tested via the injector, the rest tested via the glow plug holes?
