B5100e Transmission parts
Satsuma
B5100
Sep 16, 2018
12
Ireland
First of all, I have just registered here and it***8217;s great to see an active forum on tractors. Second is that I need a part that is available new but v expensive. My b5100e has had a replacement (cheap rubbish) bearing fail and take out part of the transmission. Just asking on the chance that someone knows of one that is for sale or has transmission parts for sale I am in the UK but I guess shipping is an option. I checked the links suggested by the main forum but not seeing any there.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the OTT forum Satsuma. Glad that you joined and you sure came to the right forum to get help.
Did you check out the part numbers that you need. I would start by looking up each part to see the cost and availability.
6,445
What parts do you need?
Satsuma
B5100
Sep 16, 2018
12
Ireland
I have posted some pictures, the last picture is the real issue, this cog links the drive shaft to the gear box (middle picture) by driving the cog on the front of the gear box (in the first picture). This part is done and can***8217;t be repaired. I need the part in the last picture and the bearing that it fits into. The middle gear on the first gear shaft (middle picture) has one tooth that is not great so ideally I would replace it also.
If I can source a used transmission that would be good but maybe someone has those parts I am needing to replace instead.
sheepfarmer
Nov 14, 2014
4,449
677
MidMichigan
Satsuma the forum software will not allow you to post a picture until you have made at least five posts. Keep the conversation going until you reach 5 and then put up pictures.
Satsuma
B5100
Sep 16, 2018
12
Ireland
Hi All
With a bit of detective work I was able to source a transmission whole, still cheaper than a new part from Kubota. Thanks to those who offered to look for parts, I just can’t find the part numbers requested, the part cost came from local who fixes these and I never got the part number, anyway it seemed to make sense to try to get a full transmission after advice from local old school mechanic. Will let forum know how I get on putting the little b5100 together. I am also thinking of overhauling the engine next so maybe more updates on that.
