Comes up often, and often they can run hot. Usually gummed up radiator.
Started mowing other night and within ten minutes I see this:
Holy smokes!! (Not what I really thought)!!
But wait a minute...haven’t run long....
Shut her down. Get laser thermometer. Top radiator hose is 135F, bottom hose is 95, and the valve cover is 127......not even to operating temperature yet.......hmmmm....
Radiator full to top, and cleaned out last week. Reservoir is good. No bubbles in radiator when running (indicator of probable head/head gasket damage).
Pulled wire off sending unit:
A little brush-brush and wiggle-wiggle. I got this on re-start and it never moved while mowing. It was about 80F:
I’ll put some dielectric grease on that connection because it’s gotten me before.
For you new guys, ALWAYS heed what the gauge says.
Don’t assume the gauge is wrong. You could end up overheating your tractor causing thousands of dollars in damage.
A $10 or 20 laser thermometer is worth it’s weight in Gold!!
