Finish mower bent wheel spindles
Dunbar
L2501 LA525 QA PFL2042 Forks RCR1860 FDR1672 BB1560 EA55 WR Grapple FitRite TnT
Aug 2, 2018
215
I picked up a FDR16 on CL for $600. It's in great shape except that the spindles (shafts that hold the height adjusting bushings) are bent. The front 2 are bent enough to affect spinning a bit and the rear 2 just a tad.
Can I heat these and straighten them out? I see that I can purchase the part, its connected to the bracket arm that holds the small axle through the wheel. I can also buy the whole wheel assembly. The thing is in great shape otherwise as the seller purchased a zero turn and a Bush Hog so set this one aside.
Here is the CL ad copy: FDR16 Series about 2 years old, used less than 5 times. Asking $800 obo. Only selling because we bought a bush hog for the pasture instead.
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
333
97
Ottawa, ontario
You could try and straighten them out but in my experience it will be difficult to get them perfect. If that's how the finisher was used for cutting no wonder it bent. That's a lot of force being put on the spindle vertical shaft.
5,559
If you know someone with a press, take all four off and have them straighten them. It's not a big deal, and they don't have to be absolutely perfect.
6,367
That fact that he was using it at full height in a pasture kind of explains the spindles being bent. :rolleyes:
Dunbar
Aug 2, 2018
215
Thanks for the ideas. All the other used ones on CL looked like crap and were priced $1,000 higher than this one . The deck is perfect. Belt covers, belt, blades all appear new. I could buy 4 new wheel assemblies for ~ $500 and still have a great deal on it. I checked the oil and had them run it for me. I'm excited about the purchase despite the bent spindles. I have a new RCR 1860 to take down the big stuff and this guy will have easy grass duty.
Sent from my SM-N950U1 using Tapatalk
Smokeless
3901/Loader/Rear Blade/Box Blade/LP Mower/Pallet forks IH M,,Cub & sickle mower
Feb 5, 2018
237
9
Southern Illinois
I have a 1672 behind my 3901, love it. Never used one before and the previous owner warned me about where and where not a finish mower should be used. We have a woods BH for rougher areas.
Had to replace the belt, $76.00, and i paid $900.00 for the mower. Probably some high, but new ones are about $2400 i believe. Mine loves to run at 2500 rpm
Sorry, no words of wisdom on my end, but i do know if it were mine i would back it in the garage and heat them. Failing that option a press is probably best option.
Hope it works for you.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,115
1,231
Near Lancaster, PA, USA
What D2 said. I've bent the stems on my LP FDR1672. I don't have a press, but I do have a pipe bender. By inserting the stem of the yoke through the bender frame at a right angle, the piston of the bender bends the 1" material as though it;'s a Tootsie Roll. I have no idea how much pressure the piston exerts, but it can bend up to 4" Sch40 steel pipe.
I think the main culprit for mine getting bent is hitting the raised edge of paving while swinging a turn.
Duke
2018 Kubota B2650 HDSC with FEL and 72â€￾ rear blade.
Jul 29, 2014
31
Metamora, MI
I bent one of mine by backing up into a pine tree trunk. Ooops! :eek:
I'm going to try to straighten it out the same way but need a way to keep the caster 180 degrees out of position.
Dunbar
Aug 2, 2018
215
I went ahead and purchased new spindles. I thought the unit was a 60" when I was looking at it and after I purchased it. Later I noticed that it is a FDR1672 72", bonus! It cuts like a dream and there is no way I would consider getting a smaller one for a L2501 if I were shopping today. I can finesse the thing into tight spots and it is no hindrance in the woods or near obstructions.
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
I have the exact same finish mower and straightened out the spindles when I bought it also. One I could use a press on and the other one I heated and straightened out. No problem.
SDT
multiple and various
Apr 15, 2018
3,251
1,041
SE, IN
View attachment 43901 View attachment 43902 View attachment 43903
Not uncommon when using a finish mower in place of a rough cut mower.
Still a good deal.
3,316
Yep... I put my new finish mower on the 3-pt and it did a fine job.
Then I used my FEL to move some things and forgot about the finish-mower being back there and backed it into a fence and bent one of the wheel-spindles. Using the shop-hyd-press it was easy to straighten back out, as that shaft is pretty soft, mild steel. The pipe idea would likely also work....but see you’ve bought new ones. Have fun installing the wheels on the new shafts. Don’t forget that center-spacer inside the wheel-halves. Can’t simply not use it, or you’ll have wheels and bearings fall apart in the field.
Dunbar
Aug 2, 2018
215
Thanks. The new shafts came with wheels installed.
